Forward shift 000 12 fret?
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=44500
Author:  sdsollod [ Wed Nov 05, 2014 12:11 pm ]
Post subject:  Forward shift 000 12 fret?
I am getting ready to make a 000 12 fret (elongated body) for the first time. I was wondering if I should try to forward shift the braces... My plan shows that the distance from the x-brace to the sound hole is 1 7/32". I am also thinking about making it a little deeper... So, first of all, should I forward shift the the braces? If so, should I make the distance between the x-brace and the sound hole 1"?
Any thoughts or comments welcome.
Author:  TonyKarol [ Wed Nov 05, 2014 12:50 pm ]
Post subject:  Re: Forward shift 000 12 fret?
if you shift the x forward will the bridge still sit on it at the ends ??? if not, you need to alter the X angle in order to forward shift ...
Author:  sdsollod [ Wed Nov 05, 2014 5:10 pm ]
I would certainly make sure that the bridge (and bridge plate) is in the right place... I just wasn't sure that shifting the x-brace forward was a good idea for this style of guitar... Perhaps I should just build it according to the plan... Although, based on what I've read, adding a little to the body depth is a good idea... I was thinking of making it the same depth as an OM, which is maybe 1/4" or so deeper.
Author:  Clay S. [ Wed Nov 05, 2014 5:35 pm ]
I have built them with the X an inch below the sound hole. The X crosses the front edge of the wings of the bridge, IIRC. You could close the X and have it cross more of the bridge, but I thought the idea was to make a "Looser" top by forward shifting the X.
Author:  John Arnold [ Wed Nov 05, 2014 7:31 pm ]
If the pattern is taken from a Martin, then it should already be forward shifted. The bracing locations were never shifted on 12-fret Martins.
The 1" measurement applies to 14-fret dreadnoughts with a 4" soundhole.
The 000 soundhole is 3 7/8".
IMHO, the X-braces should intersect the bottom corners of the bridge. That is true on most forward shifted Martin patterns.
Author:  sdsollod [ Wed Nov 05, 2014 7:48 pm ]
Thank you John. That's the kind of answer I was looking for...
